Ferroli 30 boiler,
symptoms are that the burner shuts down after a few minutes of starting when the central heating switches on.
There is usually a humming noise coming from the pump, which suggested to me that the pump was getting power but wasn't actually turning and was obstructed in some way.
Suspected the pump so removed it and got it on the bench.
Ran it a couple of times for probably about 30 or 40 seconds and it runs fine(and quietly) on all 3 settings.
Even with a reasonable amount of pressure being placed on the face of the impellor with the handle of a screwdriver, in fact now got a few flats on the handle.
So now I am baffled, is it possible that my method of testing is flawed and the pump is actually knackered.
Thanks in advance chaps.
Stu.
PS. I should add that I had also suspected a blocked system but while messing around with the 3 speeds and the bleed cap while it was in situ it seemed to start working and all the radiators in the house got hot. But this only lasted a short time(minutes) and it went back to the same problem. I would also have suspected the obvious thermostat on the wall but with the pump humming I presumed it was getting power. Should I check it anyway.
Ferroli 30 boiler,
Stu.
