Hi
Looking to lay damp proof membrane into a new garage floor slab.
We have 1000 gauge dpm roll, but I have read on this site the need to use 1200 gauge. We have plenty of the 1000 gauge so I planned to use 2 layers. Any problems with this ?
When it comes to jointing the dpm how much overlap should be used. I have read that a butyl mastic tape should be used to seal the interface and then the edge of the overlap covered with a polythene tape. Is this the accepted and normal way of sealing an overlap ?
We have a couple of plastic pipes coming up through the dpm. I take it that we can use the same polythene tape to secure the dpm to the plastic pipes ?
What is the most practical way of getting the dpm into the internal corners of the garage slab so that the concrere is the full thickness in the corners ?
Cheers.
Cheers.
