Hi I want to fit a surrey flange to the cylinder to connect to a shower pump but the fitting on the top of my tank is a male fitting looks about 1" BSP. I've checked to see if it is an adaptor but it appears to be part of the tank. there is a female fitting to a 22mm pipe coming off there going down to the hot water supply in the bathroom, can I tee off this pipe to supply the pump. Also is it ok to fit a separate water tank in the loft to supply the pump as the one for the rest of the house is not big enough to supply the shower as well and I'm limited to size where it is without reworking all the pipework
Cheers
Dave
Cheers
Dave
