I want to switch 1 light on from 4 different locations?
7 Aug 2008
Devon
I want to switch 1 light on from 4 different locations can I do that? And if I can how?
Thanks guys!
You will require two 2-way switches and two intermediate switches. Have a look at the wiki, there may be a wiring diagram there.
If you want to dim the circuit ....you can use a varilight IR master dimmer and 3 slave units... :)
If you want to be really fancy, have four sprung "push to make" switches and a latching relay :wink:
It must be friday.
But strictly speaking, you only need 4 one way switches to switch a light on from 4 locations.
I think he should. In answer to his question though... have you considered arm extensions?
..and four sprung "push to break" switches to de-latch the relay.
Could also use four occupancy sensors, one at each location.
Another option is to do it by remote control & then the OP can control the light from more than 4 locations :D
Lighting automatically there wherever you go, and not where you're not - no need to worry about switches at all...
