Hot Water in Garage
11 Apr 2007
Aberdeen
Hi
I am in the process of constructing a new garage and plan to install a sink, fed with both a cold and hot water supply.
The sink is to be fitted with a standard mixer tap.
The hot water will be used infrequently.
I have read about the 12kW RedRing instantaneous water heater as one option. Otherwise we could install a small unvented cylinder, which would mean storing a small amount of hot water.
I would be interested to hear your opinions on the 2 choices ?
instantaneous if used infrequently, no point storing water to let it cool then reheat just for the sake of it.
NO point being extravagant:
This Redring unit will need a 50amp supply.
If that is a problem to arrange in a garage, or you have an electric cooker or a shower elsewhere, think of a small oversink/undersink heater.
Such as a 3Kw stored water unit with maybe 10 litres in it. It won't take long to warm up.
ChrisR, thats one of the funniest things I have seen in a long time, thatnks for starting the weekend off with a good old chuckle!!!
