I don't see why not.Regular PTFE shouldn't be used on gas joints
So is it your belief that everyone who made a gas joint before PTFE tape was introduced was incompetent?but you shouldn't be working on gas pipes if you don't know that.
normal ptfe is different from gas ptfe
Gas PTFE is a lot thicker than standard PTFE ( although I dont think its any different chemically ) Tony
Is there any difference between using gas PTFE taps and more turns of standard PTFE?
CORGI is not any kind of authority on materials and fittings used for gas work.So anyone know? What's the CORGI answer?Is there any difference between using gas PTFE taps and more turns of standard PTFE?
Because it's incredibly useful, and because gas PTFE is often too thick.Which raises a different question, why is the thin stuff sold for plumbing?
He was talking about his own head.I once asked a gas fitter in a plumbers' merchants why PTFE wasn't used on gas joints (this was before the gas tape became available).
He said; " It will EXPLODE!"
He was talking about his own head.He said; " It will EXPLODE!"
There are standards.There must be a standard text book answer
How's about EN331:1998, and BS 746:2005, and BS 1552:1995?I don't have the British Standards listed on the Screwfix PTFE.
I don't see why not.But it shouldn't be used on coarse threads.Because it's incredibly useful, and because gas PTFE is often too thick.Which raises a different question, why is the thin stuff sold for plumbing?
I agree, and at no point did I imply otherwise.The only fine threads you see in plumbing are on some compression fittings and they don't form the seal, so you wouldn't use PTFE on the thread.
