Hi all, wonder if anyone can help?
A few weeks ago I managed to leave our immersion heater one all night (thought I switched it off, but assume I must have switched it just as the timer was switching somehow... anyway...). Woke at 2am to hear it boiling away. As bad luck would have it, the overflow pipe in the loft from the cold water tank fell off, and so we had a bit of leakage into the spare room. So two failsafe mechanisms (three if you count stupid me not switching it off) failed. The overflow pipe is now more securely attached, but obviously I want to make the immersion work properly too.
Obvious solution - replace the immersion thermostat. No problem, bought one, installed it and connected it exactly as the old one. However... it hasn't fixed it! The element is powered regardless of the thermostat setting and water temperature. If I fiddle when the water is pretty warm, then I can hear the thermostat click when I rotate the temperature setting, and if I disconnect the stat from everything, and stick a multimeter on the terminals then the contact between the two is definitely being made / broken along with the clicking. So the new stat appears to be working. So the only conclusion I can draw is that the circuit connecting the mains supply, element and stat must be wrong in some way (either connected wrong or failed somehow). The heater isn't wired up simply with the mains supply going to the element, with the stat interrupting the live feed. Instead the stat is connected to a couple of other terminals. I'm no electrician, but my guess is that this is some kind of relay type thing, so that the full current doesn't go through the stat, but the stat's open/closed status is translated to chunkier wiring inside?
Any ideas as to what could be wrong? In case what I've described above makes no sense, I've put a couple of pictures up. One is a dodgy camera phone photo, but because that's not very clear I've also drawn a diagram describing it.
Photo:
http://picasaweb.google.com/graham.searle/House/photo#5236886539137448978
Diagram:
http://picasaweb.google.com/graham.searle/House/photo#5236891538981706258
Thanks very much for any help! I realise, of course, that just replacing the whole immersion heater unit might be the sensible solution, but it's hassle I could do without if it can be solved by simply switching a few wires around!
Photo:
Diagram:
