This is the RCD in my CU. I had underfloor heating installed in my bathroom and the sparks connected into my upstairs ring (its just a 2m2 mat). Reading on here the RCD should be a lower rating for this application?
out of interest, with this RCD its total load should not exceed 80amps?
Yet we see 5x 32amp MCBs connected to it? Is this overloaded?
Or am I way off?
You should look inside the CU, or have someone look if you aren't confident about removing the cover, and see if there are any cables coming out of those MCBs. If there are don't leave them on, as you've no idea where the cables go, and what's been done to any ends.
