Control box to bell connections
28 Aug 2008
Fife
Hi
Long time lurker first time poster!
I have an alarm "kit" which I got from ebay a while ago and now the seller seems to have disappeared so I cannot ask the question.
I have it all fitted and seems to work but I cannot figure out how to connect the control box to the external sounder.
The terminals are labeled:
Control Box
Strobe +
Strobe -
Bell +
Bell -
Bell Hold -
SMB TMP
Sounder
ST-
R-
H+
H-
RTN
Thanks for any help, it will be much appreciated!
wont work, terminls missing in panel
in the sounder H+ and H- are hold off (12v supply)
R- is negative ringer
RTN is return
st- is a waste (er, strobe)
Thanks for your reply. Not exactly what I wanted to hear though!
When you say wont work, is that it? the whole thing wont work? or for example can i get it sounding perhaps minus the strobe or the tamper protection? (its going 3 stories up on a flat so if someone did manage to tamper with it they deserve to get in with acrobatic skills like that!)
look at what termianls i have written that are required, now look at what you have written your panel has. see what is missing (i doubt its actually phyisicaly missing, just you missed it.
how about a close up picture?
Yes you are right the correct Control Panel terminals are:
Strobe +
Strobe -
Bell +
Bell -
Bell Hold -
SMB TMP
Does this look any better?
I've edited the original post to include the correct terminals too.
Control Box
Strobe +
Strobe -
Bell +
Bell -
Bell Hold -
SMB TMP
Sounder
ST-
R-
H+
H-
RTN
strobe- to st-
bell- to r-
bell+ to h+
bell hold- to h-
smb tmp to rtn
try this! i hope it works :)
Hi
I've tried this configuration but now when I try to setup the system I keep getting a "Low Batt" error. I did have the system configured without the sounder so I am quite sure the battery is ok. I've put a meter across the battery in the Control Panel and it seems fine, do you think the panel monitors the battery in the sounder?
Thanks again.
yes.
as i first said, i think you are missing a terminal, i did ask you to post a picture, but you chose not to.
I have since added a (basic) explanation oif how it works in the sticky section. you should be able to figure it out from that.
alphaalarms, i thought better of you.
ignore all the rubbish and try what iv said! best of luck :lol:
think you will find that rosstheboiss did try your idea, and it did not work, he said
alphaalarms, I've tried what you suggested and breezer although not being an expert I'm quite sure an incorrectly wired sab would not result in a battery error. Also this error still appears when the sab is subsequently disconnected. I did not post a photograph as I corrected my original mistake.
SO... in conclusion (so far) I'll check the battery fuse etc. tomorrow when I get time. Good news and I'm always sure this counts; alphaalarm's suggestion did not result in an instant alarm, bangs or smoke so it may still be correct!!
Does this panel have a manufacturers make & model number on?
Same for the PCB in the bell box ?
