CCTV web server output to AV port on a TV
20 Aug 2008
Clwyd
I have a CCTV camera connected into a CCTV web server so the picture can be viewed remotely over the web or from a local PC
The web server also has a video out port (BNC) for connection to a local monitor which I've never used and I would like to be able to connect this output to an AV input on the TV.
The problem is that the TV is a distance from the web server and I won't be able to run an AV cable but I do have an unused Cat5 cable to a socket behind the TV which was put in just in case the ethernet port on the SKY box ever got used and the other end of the cable is close to the web server
I am aware that there are CCTV baluns available so that you can use cat5 to connect a camera to a web server so my initial thought is to connect the web server output to a CCTV balun and use the cat 5 cable with the other Balun at the TV end and use a BNC to AV connector and cable to connect to the TV port
That would be too easy so there must be a flaw ?
Does anyone know if this will work
Thanks Lectrician
Just wanted a second opinion as I was a bit suspicious that the solution was simple and also cheap to provide
Will order some Baluns
Baluns? nah just try it without...
Either it works or it does not, if it does all is good, if it does not then you need to get something else.
I have seen CCTV run on 4 core alarm cable before, it worked.
connect it to a SCART plug & away you go.
You are kidding?
You need to use bulans. Unless you have an Argos special DIY CCTV system.
No I'm not kidding, I said "try it" who knows it may work.
Sometimes when boards are designed we design the inputs to that numbnuts can connect almost anything to them. :D
SO the suggestion is to simply try it first.
My guess is it might just work if it is a short run but you will get far better image quality with the right baluns.
If someone has cctv installed using alarm cable then I hope the alarm company did not install it - if they did, I would recommend changing to a different company straight away.....
Alarm cable can work, but why throw away what little quality you get on cctv with the wrong cable, when its not that much more expensive to do it properly....
Who said a CCTV company had installed using alarm cable?
I was just saying that I have seen CCTV running using it, sometime you dont need to go too technical with things & sometime esp for short runs it just works. Just like you can make an aerial with wet string :D
I'm not suggesting it should be a permanent solution, just to try it.
Thanks for all the responses
I hadn't conscidered connecting directly to the cat 5 and although this may work OK I've gone for the option of using video baluns as I don't want to lose image quality and to quote kensplace "its not that much more expensive to do it properly"
