Plumbers Mait not sealing the hole
1 Sep 2008
Leicestershire
I installed a new cistern on my toilet over the weekend. All seems to be well apart from one thing.
The new cistern came with an internal overflow, but the cistern has a hole in the bottom, opposite the inlet, where the external overflow pipe would have gone. That hole is filled with a plastic bung but when I fitted the cistern and filled it with water that hole dripped slightly.
The guy who sold me the cistern told me that was perfectly normal and suggested I just bung up the hole with Plumbers Mait.
I started by putting a layer of PM over the outside of the plastic bung, covering the whole bung, but the water just dripped through the PM. I then tried sealing the edges of the plastic bung inside the cistern (under the water) but that seemed only the increase the speed of the dripping!
Finally I put another layer of PM on the outside of the cistern so that the plastic bung and the first layer of PM are completely encased in another layer of PM, but still water is dripping through the PM.
What am I doing wrong? How can I stop it dripping?!
the guy who told you its normal is a pilock then its not normal.
you should have a black rubber seal on the hole stopper.
they should seal without any problems.
if not try a smear of clear silicone around the seal but not plumbers mait.
but you shouldn't need anything if you have the rubber washer
Thanks for the quick replies.
That blanking off plug looks like the one in the hole, but I don't think it had the black washer on it. I can't tell now because it's covered in Plumbers Mait!
So what's the best way to get all this Plumbers Mait off without smashing my cistern?!
washing-up liquid and the wife's toothbrush (while she's out)
Will washing-up liquid really do it? This stuff says it sets as hard as metal and it feels pretty solid...
If its the side inlet then water should not reach that point, adjust the float to lower the water level.
:wink:
