We have an SD620F, which for a while has been making a bang (a much louder than normal ignition) as the hot tap is turned on and something (not sure if it is the fan or pump that can be heard) seemed to be excessively noisy. Now, the boiler is not working at all. There is no hot water/central heating.When the green button is held, the ignition sparks but the pilot light does not light, and there is no noise from the fan/pump (again not sure which would normally be heard). There is 1.5 bar pressure.
Is it possible that something can be repaired to remedy this problem, even if very short term as we're due to get married on Saturday and then we're away on honeymoon, so money is tight? Typical!
Many thanks,
BS...
Many thanks,
BS...
