McAlpine flexible wc connector to Saniflow macerator?
18 Jun 2007
Hi all.
My scenario goes as follows:
We're fitting a bathroom in a basement, tanked with concrete floor and ceiling. Limited height means I have had to sink a macerator into the concreted floor & then cut a gully for the shower waste to get my shower drain angle as I can't raise the tray.
This means the pan doesn't line up with the macerator, and I am needing a flexi connector to link them.
I called Saniflow who said you can't do this but I can't see why.
Has anyone done this before? -If so how did you link them?
The macerator attaches via a 4" rubber adaptor with a jubilee clip, so a McAlpine flexi to soil pipe are too large, and too small if you remove the ribbed bit.
Can you see why I can't self amalg tape the bit without the ribbing to make it 4" of this and use one?
Cheers
Tex
I'm going to make an S from 4" pipe and a couple of bends, flexi turns out to be too messy. Bloody hope it works or I'll have to lower the whole floor :shock:
Don't get too hasty - how about posting some pics of your problem, and maybe some relevant dimensions, might be able to help further...
Ta mate; but I've tried and although it will work it moves the pan out too far from the wall; just looks too odd.
Instead of lowering the whole floor, I'm going to run the shower to another flippin macerator, that way I can get away with just making a gully and hole for the Sanishower.
Ta for your help tho Muggles
