That clamp isn't fitted correctly - the warning label should be fixed under the central screw/nut, not by using the strap through the slots in the label.
That's why the label has round holes in it.
"For meters in outside meter boxes/compartments, the bonding connection should be preferably inside the building and as near as practicable to the point of entry of the installation pipework into the building."
Sorry to hijack, but if the meter is external, and the pipe runs up outside and through into the third floor flat, the bonding connection would be (in my case) about 12m from the meter.
It should be within 600mm of where the pipe enters the property. If it enters the property 12m after the meter then so what? Bond it as close as you can to the incomer.
