I'm decorating my front room and want to remove the radiator so I can remove the paper from behind it. I note that the radiator is fed with two microbore pipes on the same side using a twin entry valve. I know that if i turn off both the valve and the return valve (under the cap) I can take the rad off (being carefull of the pipe inside), do what I need and put it back, but - do I really want to?
Having read else where that these type of fixtures are no longer made and can now cause problems in ageing systems, would I be better to get someone in to replace the rad entirely for a new one with modern fittings?
My concern here is can I do that with one rad or do I need to do it for all that come off that floors manifold?
Thanks,
Mike
Thanks,
Mike
