Please refer to my bathroom album first.
//www.diynot.com/network/daffyduck1962
I want to build a frame off the wall to cover the pipes to the left of the bath. I plan to make 2 separate section, one either side of the pedestal. Each will be finished in wall tiles.
I want to have the finished article so the tile surface is level with the edge of the bath. Calculating the height for the frame would be easy if I knew how deep the tile adhesive bed needs to be. Can you advise please?
I also need to fill in the void behind the taps, and thought I would use a 2 x 4 baton frame, cover with plywood, then tile. the height of the box will one full tile's height for looks, finished with a small shelf which will overhang and allow shampoo etc. to be to hand. Do you recommend tile strip or silicone as a water tight seal around the bath's edge?
My last bath had silicone but was always turning mouldy. However I have heard that edging strip can become hard and warp over time allowing water to seep in behind and onto the floor.
