Use steel plate as 'padstone' to rest RSJ on wooden support?
17 May 2013
So our cabin modifications are all signed off. We went with steel, so a 6.4m 254x146x31 UC RSJ resting on 10cm deep nibs in our wall:
upload_2019-11-13_11-19-4-png.35022
The SE was happy we replace the 200x47 with something of the same support area so we are likely to have a supporting area approx 210mm wide, e.g. 3 70mm timbers side by side. I know putting RSJs on (old) brick you often use concrete padstones to support the load; the engineer has not specified it but should I do similar to spread the load from the 146mm wide steel over the 210? Or is that just serving no purpose?
I was thinking I don't want to put a concrete block up there, maybe I could get some 10/12mm steel plates made say 210x130mm.
OK, caught the SE after all. He's happy without it as long as the 3 verticals are securely fastened, e.g. M10 bolts at 750mm centres.
Just in case anyone was interested... I must post some photos later of how it's going.
