I have these striplights under my kitchen unit and they’ve recently stopped working. I’ve been doing some troubleshooting and can share the following:
- I’ve used each of the 3 interconnected lights individually and none of the work. I found this strange...
- there is AC power detected by my 2 pole tester at the connector that slots into the strip lights
- the power will appear/disappear when flicking the switch
- there is also power at the mains cable leading to - I assume a driver - the driver is inaccessible
I could purchase a new strip light and try this but I find it very odd that none of the three interconnected lights work when used separately.
is the issue possibly with the driver but this still means that voltage is detected by the 2 pole tester?
