- Joined
- 31 Mar 2017
- Messages
- 190
- Reaction score
- 44
- Country
This incident is now a police inquiry. The gas pipe was cut inside a property. ... https://www.bbc.co.uk/news/uk-england-lancashire-57232373
Ok. Let’s put the tragedy aside for a moment. Let’s speculate why a gas pipe anywhere would be cut before the meter. You first.Should we speculate that because its a police inquiry its looking like a cut before the meter so as to steal gas rather than the HSE investigating desperately incompetent unregistered gas work?
a little bit off topic.. but Ive always wondered why the whole underground gas pipe doesn't also blow up. So, why doesn't the fire go into the underground pipes and theoretically blow up the whole of the gas grid?Just thinking that if someone wanted to steal gas theyd have to divert some or all of it from the pipe before it went through the meter.
£££'s?Ok. Let’s put the tragedy aside for a moment. Let’s speculate why a gas pipe anywhere would be cut before the meter. You first.
I think, it can only burn in the presence of oxygen, i.e. at the end of the pipe. Once it's burning, it can no longer explode, maybe?a little bit off topic.. but Ive always wondered why the whole underground gas pipe doesn't also blow up. So, why doesn't the fire go into the underground pipes and theoretically blow up the whole of the gas grid?
that's interesting... so hypothetically say you cut into the mains gas pipe in your house and gas starts escaping - then you immediately ignite it with a match.Gas on its own does not burn - needs oxygen.
Is all that's gonna happen is that it will be like a giant blow torch? (a bit like a flame thrower)
It doesn't need safety valves. As the Captain said, it needs oxygen to explode. Lower and upper explosive limits, LEL and UEL (in air) are about 3% and 15%.thinking about it.. it must have some safety valves built into the gas network.. a bit like a blow torch. So just because you ignite the blow torch doesn't mean the canisters gonna explode or what @Captain Nemesis said!
