- Joined
- 11 Sep 2020
- Messages
- 40
- Reaction score
- 0
- Country
150mm Soil Pipe – Advice Needed
Hi all,
I'm looking for some advice. I currently have an application open with Severn Trent to modify an existing shared drain. The plan is to relocate the 150mm soil pipe 150mm away from the proposed footing for an extension. The replacement would be a plastic pipe of the same diameter, laid entirely within my own land, and installed with slow bends.
My main question is: can this work typically be carried out by a competent builder, or would Severn Trent usually require a specialist drainage contractor for this type of alteration?
Any insights appreciated—thanks!
Hi all,
