- Joined
- 11 Jan 2004
- Messages
- 45,920
- Reaction score
- 3,533
- Country
We have had a damp Patch on the garage floor for a good few weeks now.
It's right near an incorrectly fitted PVC door (IFD). The door has been like that since we moved in in June 1999.
I thought there might be water getting under the door, but I sprayed a hose under there for 20 minutes and nothing came through the other side.
Next to the damp patch is a washing machine but there's no sign of leakage there. Besides, the damp patch does not spread that far, on the surface, at least.
But outside, next to the IFD is a drain that has been added to over the years and is overcrowded.
Sometimes, I go outside and see that water has overflowed from it. The edges of the pottery are crumbling and I'm wondering if water is leaking into the surrounding ground and up through the concrete area inside the IFD.
Is this remotely possible, or am I being daft?
The WM is just to the left of the damp patch behind the ply panel.
The IFD is just to the right of the drain.
I'm wondering if I should lift a flag or two and see if the drain is broken, or try to find out why the ground underneath the flags is saturated.
