In my picture below have I identified correct for flow and return pipes ?
To fit a Ady filter on returnCare to elaborate on what it's for? You can do as above, but can also be traced back to the boiler.
First time fitting on a heat only system. Just want to be sure before start . Got no problem with bunging f n e and vent. Isolating water and wet vav ing the remainder water in pipe so no water when cut it.You are looking to get an answer to a question that could not be more basic yet are not worried what could happen post cutting the pipe to install the filter
Is this return ( In blue) 'm not up on identifying on heat only. Combi would not be a problem . ThanksIf the pump is going to 3 port, that’s usually the flow
There no room at the boilor the pipes are tight to the ceilingWhy not fit it by the boiler? The primary return is most likely under the floor, not in the airing cupboard
There no more pipes apart from ones in imageNo off the 3 port will be heating flow and cylinder flow for hot water. Have a look at the cylinder there’s 2 connections if indirect, one will be flow from the 3 port the bottom should be return
I think you may be right. The return is not visible in cylinder cupboardWhy not fit it by the boiler? The primary return is most likely under the floor, not in the airing cupboard
