hmm how to connect this old thin pipe to 15mm, cut it under floor and add 15mm to 10mm flexi elbows and john guest flexi pipe to vales? I have new legs too to cover the pipes. Or use reducers at the valve? either way I need to move the pipes to fit new rad width.
