Apologies if this has been discussed before.
So we have had an indirect unvented cylinder (Joule Invacyl) fitted which is heated by a Worcester Greenstar Ri boiler in a Y plan configuration. We have had a hive dual channel installed a week after the cylinder.
The heating stopped working after the cylinder was fitted but hot water was fine. We thought it was an issue with the old programmer so just waited for hive to be installed and it didn’t solve the problem, diagnosed it as the Honeywell 3 port valve which was swapped and the heating still didn’t work but hot water does. The valve now moved to the right position but the boiler and circulator pump don’t kick in unless there is a call for hot water. After much head scratching, testing with the multimeter and studying of heating wiring setups I have realised it’s because we have the hive set to hot water always on so there is never voltage going down the hot water off wire which is what supply’s the boiler with voltage.
I want the hot water to just be set to always on in the hive and just have the cylinder stat manage it by kicking on when it dips below the set temperature but this means I can never turn the heating on as the hive receiver is never sending voltage down the hot water off line.
My thinking was to link the hot water call wire from the hive receiver to the hot water off wire in the wiring center. Is this a viable workaround to this or will this cause issues? Is there another way to make this work properly?
Thanks for your help.
