Amateur DIYer about to start next project.
I'm looking to put built in cabinets and shelving in my living room alcoves, similar to the photo attached.
I'm comfortable with building the cabinet and plan to build the shelving above in situ.
I plan on using 25mm MDF for the vertical partition and shelves.
I'll fix 25mm MDF to the walls on either side and then a board at the top which will will eventually be covered by trim.
I'd fix the vertical partition by screwing upwards from inside the cabinet and down through the board across the top.
Where I am a bit stuck though is the shelves as I won't have access to screw these in from the outside.
Would sinking screws at an angle and covering with filler be the best way? From experience I've struggled to fully sink the screw when doing this in the past.
Ideally I'd want to avoid having any visible brackets if possible.
On a side note, the width of each shelf will be around 640mm. Would I likely see sagging at that length if using 25mm board or should I be ok?
Thanks for any advice given.
Dan
Dan
