Hi All,
I'm hoping you can offer some advice on an issue I spotted at the weekend.
We've recently moved into a house with a detached garage and when all the rain came down on Saturday I noticed it was coming in to the garage from one of the corners.
After it stopped i had a quick look outside and could see some loose/missing bits of pointing round the edge and on the stairs.
Do you think it's a case of patching up the bits that have come off, or is it worth removing and redoing? What sort of material would you use? Cement, screed? Combo of both? Or is it a case of it needs a bit more than that?
For what it's worth here's the aftermath today, mostly dried, but still on bit which looks quite damp.
Thanks in advance!
Thanks in advance!
