Net Zero Rollback
but it should not be forced onto people/industry
the problem with making stuff voluntary is that profit making businesses always make decisions based on cheapest short term option
we only have to look at water companies - they are happy to pump sewage into rivers because its cheap option
Green tech should be a choice and not forced onto people, period. Take Khan for an example, because central govt has cut grants to TFL , he has enacted many anti car policies in conjunction with councils to rinse the motorist to make up for his budget shortfall and fund vanity projects This has made very difficult to move around and you now find traffic fighting against each other and ius being replicated all acros cities in teh UK
Yes, before Safiq Khan was elected by Londons traffic was minimal and drivers smiled at each other and the only gridlock on London streets was due to two people insisting that the other should go first.
This was discussed on Debate Night last night, it's like a Scottish QT.
A person on the panel put forward a reasonably balanced argument, assuming that is you agree with net zero objectives and further agree renewables is thee way to achieve this.
Her assertion was we're going through a transitional period, a period that will take years if not decades. i.e. the massive and gradual transition from fossil fuels to renewables. During this time she asserted, higher costs are an expected consequence e.g. due to building the renewable infrastructure and so on.
I think that's a more honest stance, rather than listening to politicians who tell us our energy bills will come down. When exactly?
The problem is electricity as a cost per KWh of energy is 3x more than gas.
Moving to a heat pump from a gas boiler only works financially if you have solar + batteries
Moving to a heat pump from oil boiler is quite possibly a good move.
But heat pumps are often installed with badly designed and specified systems
they have improved a bit, but the primary issue is the ability to operate at a higher temperature to power a conventional central heating system.
I've no problem with the cost and already have a multi-room air-con setup, its replacing the boiler that is the issue.
Didn't Boris start this ?
Green taxes/levies does form a part of the high costs, add up to £140 on total bill, been going on for years.
it costs an average of 11% on a dual fuel bill
meanwhile the cost of fossil fuel price rises on energy bills in 2022 and 2023 was more like 50% or more
thats not quite as it seems
the policies were also supported by the Conservative government:
(note this letter shared on social media is true, however the letter was in regard to extending the boundary to the extent of the South and North circular roads not greater London, so its true Sadiq Khan extended somewhat beyond the scope set by Conservatives
F2I5qzZXoAQ8r8a
I would also point out that the measures Sadiq Khan put in place were also working towards the targets set by the Conservative govt in their Clean Air Strategy
Yes its true , about covid times to get peole
F2I5qzZXoAQ8r8a
Yes, the tories were also at the time into green policies but the wind has changed, they encouraged LTN'S due to covid and enourage walking but labour councils pushed it through big time, Sunak at the end of his term did push back on this as well. With green policies the common man sees no benefit.
I agree that LTNs and ULEZ are not the answer
I know that ULEZ damaged businesses who work on the cusp of the zone area
the biggest failure in my opinion was the massive error in getting the car industry to move to diesel in the basis it was cleaner
having the highest energy cost in Europe makes no sense for industry as it pushes up prices for evryone.
but as I keep on saying: that is not due to net zero
I must admit Im glad I no longer run a joinery business with all that heavy machinery, plenty of them had multiple 25kw motors. in 2017 I was paying £500 a month for electricity. Lighting alone was 4kw /hr
You do make a lot of sense here though - I agree with it all apart from the last bit
You don't pay carbon taxes. That's something that big emitters do. But it is a way to overcome Jevons Paradox.
