I said its the BLADES that are the problem not the whole thing
A problem.
So do you think that because the old turbine blades have not been recycled, that makes wind turbines bad and shouldn’t have been introduced?I said its the BLADES that are the problem not the whole thing
No - you are making stuff up againSo do you think that because the old turbine blades have not been recycled, that makes wind turbines bad and shouldn’t have been introduced?
So which is the con part?No I do not - you are lying again - that is not the con bit.
To give a sense of scale there might be 60,000 tons of wind turbine blades a year over all of Europe.
That is a large number, but you have to put into context. Manchester which diverts 99% of its household waste to non-landfill generates around 10,000 tons a year.
The EU uses around 130 million tons of landfill a year. So blades waste would be 0.05% of all landfill waste.
One ton out of every 2000. Any waste is bad but it's not even a rounding error.
Like the UKs contribution to world CO levels. Virtually nil.That is a large number, but you have to put into context. Any waste is bad but it's not even a rounding error.
Nope, the UKs contribution to climate change is roughly in line with population. We're (very roughly) 1% of the population and cause roughly 1% of emissions. And we'll only need to spend around 1% of the total to mitigate it. But probably more than 1% of the cost to adapt to it as we're vulnerable. How much will it cost to move Hull when flooding gets too bad.Like the UKs contribution to world CO levels. Virtually nil.
Not entirely true when you consider how long CO2 can stay in the atmosphere:Like the UKs contribution to world CO levels. Virtually nil.
Shmuck.Virtually nil.
Try being nice, you might enjoy itI see m-itch's research has improved to.....
Shmuck.
It's interesting that you think by pointing out falsities, misleading waffle and outright lies - is me not 'being nice'.Try being nice
Theres a better way to do it but whatever, carry on...It's interesting that you think by pointing out falsities, misleading waffle and outright lies - is me not 'being nice'.
No ta. I'll continue to point out the RWR failings just the same.
