Hi all another one of many insulation threads. I have gotten pretty lost and have struggled searching for insulating information, when dealing with a non-breathable, vapour closed bitumen-like felt membrane. I believe the bay wall is felt with a roughcast rendered finish, no bricks.
1) Bay lip - PIR triangles/wedges (foil to warm side); foam edges; foil-tape warm-face seams.
2) between outer vertical studs 1st layer at cold side - the vertical beam thickness / space from horizontal beam to DPM is 90 mm.
- Full fill so the PIR is against the DPM OR leave air gap (20-25 mm)?
- If "full fill" - the DPM bulges at points, with a 90mm board should I scribe into the board to account for DPM bulges or achieve 85 mm thickness (60 mm + 25 mm PIR).
- 4mm air gap on cold side okay?
- finish with perimeter foam and tape
3) interframe thermal break with rock wool 25-40 mm - so there is no foil on foil space that is breathable
4) PIR board over bay void plasterboard (below room ceiling)
5) second frame with PIR
6) VLC bay wall insulation
7) infil void with rock wool up to floor board
8) VLC below flooring - with tapered 3 mm OSB between floor joists then taped osb and tape edges or air tight membrane, then floor down down.
8) plasterboard
The non-breathable membrane has really confused me. I had originally wanted to rock wool the entire space (previously posted here).
8) plasterboard
