- Joined
- 27 Jan 2008
- Messages
- 27,493
- Reaction score
- 3,323
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
This
seems to be the CH (top) and DHW (bottom) links. I don't know why DHW can be turned on/off with a combi boiler, and you have not linked to the manual. I would only connect Nest to the CH and would leave DHW always on.
Seem to remember two DHW options, Eco on and Eco off, with Eco off the boiler had a small reservoir of hot water, so taps don't need to be full on to get hot water, but if used with a shower it can run out and go cold under the shower while the boiler get to temperature.
As said, my home has 14 heated areas, and the TRV heads do most of the control, so a system which will not allow TRV heads to be linked in is rather useless. I have moved to Wiser.
