Our bungalow has 60a, will need upgrading to 100 which UK Power networks will do FOC.
I have what I measure to be 10mm cable in and out of the meter into fuse board.
For anyone who may have experienced (or even had done) the upgrade my Q is, do they (UKP) upgrade to the meter only or also meter into the FuseBoard. ? I ask becuase I read that for 100A then 16mm would be the size cable but, currently coming out of the meter is only 10mm.
Its been 60A/10mm for ever so the world won't stop if they don't but I'd like to plan ahead a bit if I need to get an electrician in or not.
We've got overhead cables into the property so not too bad to do but out of interest how on earth do they do it if your cables run underground, I imagine its a right PITA.
Thank you as always for the helpful replies
PG
PG
