don't know how the builder is adamant this is 17+ degrees. I have been outside and asked several times and he is confident it is made slightly above 17 degrees.
I have used my own online resources and doing it based on counting bricks from the outer wall to the existing house wall.
Simply put, for my 3400mm length extension, it requires a rise of 1030mm ish (so just over 1m) .
So counting brick courses - i'd say that is 14 brick courses (75mm per course x 14)
I only count 12 brick courses. even looks like just 10 courses from the photo ,but he showed the outer wall is 2 bricks lower when looking it directly from the back.
How is he still so adament its 17 degrees? no more bricks need to go against the existing house side.
So maybe its not as simple as counting courses of bricks?
