How to reset temper warnings
30 Jul 2013
London
Hello
I replaced my burglar alarm 12v battery which has died.
I am now getting this lid temper warning because I opened the box to replace the battery, which doesn’t allow me to set the alarm and call installer. I don’t have the engineer code, tried few defaults but nothing worked.
The company which has our engineer code wants 210£ to come and set it.
Is there a way for me to do that without having to call them on ?
Do a stage 1 reset
This only resets the master (1) code ( 1234) and engineer code ( 7290) as it’s been programmed as lid tamper engineer reset option 38
After doing this enter1234 to stop alarm , then box up
Reset your code
Reset time and date
Do engineer reset
Thank you, I think I have that manual too :)
When you say "Do a stage 1 reset" do you mean steps 1-10 in first stage reset chapter ?
I know how to do steps 1-3, no clue how to do 4 onwards :-/ How do you short circuit those pins ?
Ah right, thanks :)
But step 7 says remove it. Am I suppose to keep two screwdriver blades on both of those pins and reconnect the battery afterwards and only then remove them. Sounds like a two person job. Also, are you sure it will only reset those passcodes and not the entire setup ? Have you tried it yourself before ?
And another question please: I don't suppose there's a way to supress this tempered warning and restore the alarm without the engineering code right ?
Yes it only resets the code
I take it you have tried entering the default engineer code ?
Post picture of control panel is there a fuse isolator at the side of it
I tried the default one yes, doesn't work, and the company who holds it wants 210£ to have it removed, not giving them that pleasure.
The control panel has a fuse box next to it which I believe is alarm related but then again I'm no expert.
Is that important to the procedure above ?
Pull fuse out , disconnect battery …short the two pins with screwdriver keep it shorted push the fuse back in , keep it shorted for 10 seconds, it should be 1234
Thanks for the walkthrough.
It also has dedicated mains power switch in the electricity switchboard, do I not need to bring it down as well (step 1 in the manual) ?
Here’s a picture of the board if it helps. The fuse box is next to it, not in the picture
I tried the procedure today, it doesn’t work.
I tried keeping two screwdrivers on both pins pairs. Any chance I need to use something else to short circuit them ?
Think I’ve managed now I’m in installer mode with the default code ! How do I apply the temper changes and exit tjis mode ?
By the way, how do I now change the engineer code from its default ?
