- Joined
- 11 Mar 2021
- Messages
- 28
- Reaction score
- 0
- Country
I plan to lay some concrete. Once set I'll be putting up a fence on either side. The fence will run along the red line in the attached pic and also along where the timber is.
For the fence posts I'll be using bolt down shoes.
Looking for advice on the yellow line in the pic. I had planned to create the form using timber on the left (red line), top (yellow line) and right (timber in pic) and for the bottom I'll just use the path.
Then I realised that if I want the fence right against the wall at the back I can't have that timber (yellow line) there because the there would be empty space left when I remove the form. And with the shoes I'd need to have them in a bit from the edge of the concrete too so the fence would be even further away from the wall.
If I don't have the yellow line timber there then I'm not sure how easy it will be to screed the concrete. There's a fall from right to left which I want to maintain for rainwater drainage, and I had planned to run the screed board along the yellow line and path (at the bottom of the pic). So the screeding would be done from right to left and not top to bottom.
Should I shorten the yellow line so there is empty space where I want to put the shoes, and screw the yellow line to the wall?
