Damp mouldy Victorian cellar.
12 May 2015
Liverpool
Hi all,
Damp and mouldy Victorian cellar here. It's penetrating damp. Not sure what a full tanking solution will cost, but in the meantime these are my thoughts...
HG Algae & Mould Remover from Screwfix is an "outdoor" mould remover, but there are double doors to the outside under the bay window at the front.
Probably need a respirator when disturbing the mould.
Then put a dehumidifier down there.
Any thoughts, advice, ideas welcome .
Edit... Also need to remove some wood racking and tables from down there as it seems to encourage it.
Hi all,
Clean the place of cobwebs & mould etc and then use for bike storage only. Keep everything off the ground. Do not store bio-degradables such as cardboard boxes or clothes etc. May be ok for storing apples and veg assuming no mice.
I wouldn't bother with a dehumidifier, it'd just be running 24/7, pulling the dampness from the outside air and the soaked damp walls.
OP,
Why not provide pics of inside the cellar, & outside at ground level?
What do you intend to do with the cellar?
You’re right to start with removing the wood and using a dehumidifier. Those help a lot with keeping it under control. The HG remover should work fine, just make sure the area’s well ventilated.
Hi all,
You will not win the battle with a sub-terranean structure regards damp etc unless it was initially built to a very high spec' with loads of money thrown at it. Accept it for what it is or be prepared for disappointment.
Hi all,
what are you trying to achieve? Habital room, workshop, storage?
Thanks, not looking to spend a fortune here.
It's just a workshop/storage area. The mould is the key worry.
Zinsser sell a cellar paint that they claim with hold back X amount of penetrating water. I have never used it.
It'd be interesting to know what that 'x' amount is. I can't see a paint holding back water tbh. Retaining wall fail due to water build-up behind, when no weep holes to ease the hydro-pressure.
They claim
  • Guaranteed to stop up to 34psi of water pressure
I have no idea what that means in practical terms.
Yes, I think spray it off, vent the room, then dehumidifier. Happy to let the walls breathe.
Dehumidifiers are another minefield, it turns out.
A 50l compressor type is about 1/4 the price of a 45l desiccant one... But the compressor types are not recommended for cellars...
