- Joined
- 12 Oct 2024
- Messages
- 211
- Reaction score
- 11
- Country
Hi all,
I had a composite door fitted a few months ago on my new extension. I keep noticing that when it rains a lot, the bottom of the frame fills up with water, to such an extent that the two draft excluder strips end up completely saturated. How they will end up drying I don't know.
I had to dry it out once yesterday where it was filling up in the middle, like a canal, then later on it seemed to be happening again. I should have left it the first time to see if it ended up overflowing to the inside, which it looked like it would with the low threshold.
I attach some photos of it later on after I'd already dried out the pooling. Does this look normal or acceptable to you? The fluffy strip things are soaked now and the rain stopped last night. Just looks like a place for mould to happen.
There are two drainage holes which work. I poured a jug of water in earlier and the water did run out over the sill. The problem is that most of the water which makes it into the centre and to the back draft strip doesn't seem to makes its way to the holes.
