Hi all,
Received quotation for brick and block flat roof build from a builder for 6M by 4M garden outbuilding. I work it out as external dimension of 24sq m. This is what agreed quote documents state.
The builder however got subcontractors for bricklaying. Must say they have done very tidy job.
However this morning when i measured the outer edge of brick to brick it measured 5.7 m x 3.7m. This makes area just over 21sq m.
The build spec has wood cladding in front. We did not agree to external insulation ( which now looks like potential solution). I have some builders remorse, as there was enought space to go 7m x 5m but i did not think it through. So now i do not want to lose internal space if miscalcuation has been made and internal wall insulation and plasterboard eats more space.
My builder is away until 10th dec.
Is the build dimensions off the project plan. Has subcontractors built outer brick leaf where insulation and block should be.
