Hi all
I have 2 outdoor lights which have recently been installed, with a separate PIR sensor controlling both of them which turns them on after dark etc etc. This is controlled by a switch indoors which turns the whole lot on or off. Pretty standard.
I want to now, for a particular reason, remove or bypass the PIR sensor, so that the 2 outdoor lights are controlled solely on/off by the switch. I can't think of an easy way to do this because if I remove the PIR sensor, I don't know how to safely connect the wires back together outdoors (and so that it looks nice, this is the front of our house), and also with the PIR sensor being there anyway, it would be nice to keep it in place for future use and when we move, if the owners would like to use it.
The PIR doesn't have a bypass or override on/off on/off way of manually bypassing it, but that is not what I want anyway, as that is just temporary, I need it to be like the PIR is not even there. Can I use the PIR as a "junction box" in effect so that it remains in place but has no effect? Alternatively is there another way of removing it an replacing it with something that would work for what I need?
PS the reason I want to do this is because I am installing a z-wave module on this light switch so the light can be added to my HA system and can be turned on and off by my astronomically aware controller etc.
