Grant Vortex 26e low pressure
22 Feb 2006
But it isn't! The low pressure LED's flashing but water pressure is steady at one bar. No CH or hot water. Is there a pressure switch somewhere?
Grant register installer here.
Simple answer link pressure swith out they haven't been fitted to new Grant combi's for several years.
We remove them every time we find them mostly because when your working on boiler they are renown for snapping off!
From memory the pressure switch connections are 15 and 16 on board just take out pressure switch connections and insert link.
If that don't do it it's the board.
Thanks for that. Could I leave the old switch in, cut the wires and bypass the board?
Absolutely take wires out of board replace with link
If you do any work on system and have to drain or even just get rid of pressure that's time to remove switch.
It's threaded 1/4 bsp so you just need a 1/4 plug.
If I just snip the wires a couple of inches from the switch, bare back and connect together, I take it that would work too? I'm just trying to avoid taking the board to bits if I don't need to.
All done, thank you, and I now have heating and water. I had ordered a switch prior to our conversation, but it hasn't shown up in post yet, so happy to bypass it for time being.
Spoke to Grant tech this morning and advisor confirmed it'll work but wasn't keen on bypassing; he said if the pressure drops and heat is still called for the boiler can blow up! He also confirmed later combis don't have the switch... I've emailed them for more info as I have a Grant bulletin explaining how to cap off the pressure switch. Odd.
Heard back from Grant. For the archives, the pressure switch disappeared from 2014 combis onwards when the existing 12 litre expansion vessel was replaced with a 24-litre one. If you have an external pressure vessel to supplement the 12 litre one for earlier combis, the switch can be capped.
