- Joined
- 27 Jan 2008
- Messages
- 28,316
- Reaction score
- 3,441
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The filament LED
I regarded as being for display, seen them in pubs, often need to take menu outside to read it as light so poor, and the cob LED
reverse, it does not look very good, so in the main I fitted the pearl LED bulb
which basic shines up from the base, and the cover defuses the light. But as one looks at Lumen - Watts one sees 806 Lumen from 7.3 watt for pearl and 805 Lumen from 6.5 watt filament, the cob 800 Lumen from 7 watt, but in general the cob design can allow a larger bulb to be fitted, from 7 to 18 watt seems common, where the other two seem to be lower wattages. The smart version seems to be pearl type, although did find these
which show an impressive 7W 800LM, but expensive at £15 each.
However, it seems the LED is moving on, but the light direction is also changing, I look at this
attempt to redirect the light from a pearl bulb, I reversed the tin foil after, I wanted a smart bulb, so I could switch in on before leaving the car, and the smart cob bulb is 3 x cost of pearl at the moment. However, it seems things have moved on, and we now have the option of bulbs which shine 90° to base, like the old tungsten bulb.
But I have swapped bulbs as daughter complained giving her a headache, swapped bulbs to upgrade to smart, and I am left with a draw full of good bulbs, so loathed to buy more. I had run out of BA22d, and my wife picked a filament type when shopping, the only BA22d she could find in Morrison's, and I fitted in the shed, then realised how much better it lit the shed.
I look at the chandelier
got to increase light output as only one lamp in the room, which is still not really enough, so we use standard lamps, and display lights to supplement it, and wonder what 8 x E14 filament type LED's would do to room lighting? But hunting for bulbs found a lot of 4 watt versions, at 400 lumens, and some adverts could not find the lumen output.
But has anyone changed to filament bulbs, and if so was there an improvement in spread of light?
which show an impressive 7W 800LM, but expensive at £15 each.However, it seems the LED is moving on, but the light direction is also changing, I look at this
attempt to redirect the light from a pearl bulb, I reversed the tin foil after, I wanted a smart bulb, so I could switch in on before leaving the car, and the smart cob bulb is 3 x cost of pearl at the moment. However, it seems things have moved on, and we now have the option of bulbs which shine 90° to base, like the old tungsten bulb.But I have swapped bulbs as daughter complained giving her a headache, swapped bulbs to upgrade to smart, and I am left with a draw full of good bulbs, so loathed to buy more. I had run out of BA22d, and my wife picked a filament type when shopping, the only BA22d she could find in Morrison's, and I fitted in the shed, then realised how much better it lit the shed.
got to increase light output as only one lamp in the room, which is still not really enough, so we use standard lamps, and display lights to supplement it, and wonder what 8 x E14 filament type LED's would do to room lighting? But hunting for bulbs found a lot of 4 watt versions, at 400 lumens, and some adverts could not find the lumen output.But has anyone changed to filament bulbs, and if so was there an improvement in spread of light?
