ARC call failed Pyronix
20 Jan 2026
I have a Pyronix V10 enforcer alarm since 2021,, no issue. 3 months back got random alerts at 2am saying Kitchen wirels Pol failed. Happened say once every 4 weeks or so, so less frequent.
There is a PIR in Kitchen which had this issue
So installer came to change battery and swapped Lounge PIR to Kitchen PIR and vice versa. He also tried to add a dual shock and contact sensor. He was unable to get that working as showed open on door contact, so didn't install.
After his service I get regular alerts, few times. Day. Installer said issue with SIM, so contacted keysim who said no issue with SIM and changed from EE to Vodafone. I am now able to login faster on app but now get 3 alerts
Kitchen Wirls Supervn F1
Control Panel ARC Call Failed
When I login to app, I get
I did walk test and all devices barring siren ok.
So Installer asked me to do the following
1. Did a signal test, takes 5 mins. Score for 3 for all 7 devices
2. Restart panel after removing power and battery
Still no change
Really suffering from false alarm happens at weird time. Installer not local so unsure how to go about.
See screenshots
Any solutions ?
Thank you
Kitchen is showing 2 in that screen shot ….how far is kitchen from alarm panel ? Move kitchen pir near control panel see if the issue stops …if so it’s a wireless signal issue
If the same PIR that has been moved from the kitchen to the lounge is causing the fault, and the battery os good then you will likely need to replace it.
If the pir that was moved from the lounge to the kicthen is causing it then you will need to look at relocating it away from possible causes of interference or closer to the receiver.
Check your ARC settings in communication menu, disable them if not using an ARC. If you are using an ARC then check the settings are correct and sign up to arc using the relevent ARC code
Thank you so much. As for the questions and comments.
2 was momentarily then it changed to 3.
Kitchen PIR was swapped to lounge and still Kitchen PIR is the cause and batteries changed, so either
1. Interference or
2. Range
But after that, ARC message and Wirls Supervn F1 error started appearing
If I disable ARC, what are the downsides ?
Thanks again.
Hiya, What should be the arc code and the downsides of not using Arc. I use gsm SIM for communication.
Thanks again.
Hiya,
Distance wise
Control panel is 1st floor front of house. Kitchen PIR on exterior wall in extension ground floor. Distance could be 20m. I kitchen we have following devices
Nest thermostat
Bosch dishwasher
Neff steam oven
None seems to have the same frequency as that of wireless PIR.
Thanks again
Faraday cage …I’ve had summer houses with foil back plasterboard and the detector would only work if across from the patio windows …
Thank you
Installer coming tomorrow to move the PIR. Will keep this thread posted for future references.
The installer did come. He said the signal strength varied between 52 and 58, so he feels something is interfering in the kitchen. I checked Nest, Philips hue, Alexa and Bosch and none operate at 833mhz. For now, this PIR has been disabled. So kitchen area has no monitoring
