What sort of a under ground dain do i need for a channel drain thanks
18 Jan 2026
What sort of a under ground drain do I need to attach a channel drain to thanks
I want to adapt the channel drain to the new drain the new drain needs to adapt to the channel drain plus the existing drain
Aco drain manu's supply fittings that convert the channel into round drainage. Drainage manu's supply fittings that allow you to retro' fit junctions or IC's etc, into an existing drain line. They also supply connectors and bends of varying degrees of turn.
Locate the drain. Expose the drain. Select the best place to cut then graft in your connection. Hire an angle grinder.
