Setting out blockwork from foundation
5 Nov 2018
Hi all. I hope you are well.
I am in the process of building a summer house in my back garden. I have just poured the concrete foundation which didn't go as precise as I had planned. The lads pumping in the concrete were pretty hasty at 6.30pm and kept telling me that being 10mm lower in some places on my level markers is ok and it can be built up in muck.
So I have a couple places either side which have around 1 metre length which is 10mm below the level I wanted. Now I need to think about laying the blockwork (just one course) for the beam and block floor to sit on. Now I need this to be as near perfect as it can be.
The advice I need is, do I set the 1st block at the highest part of the foundation and then add more mortar to get it level
Do I start from the corners 1st?
What mix of sand and cement do I use for this course?
Any advice would be great. Or any Bricklayers in Surrey would be keen to do the job? Thanks
Search for "datum peg" and "setting out profiles".
Start at the corners and work from them towards the middle of each elevation.
3:1 mix ratio.
Make sure your line is not sagging on the sides where the beams will sit
3:1 mix ratio.
Hi Woody. Thanks so much for the reply and advice. When you say search, do you mean on the forum or actually look it on on the web?
Hopefully you are still sleeping as your reply was nearly midnight.
Cheers
Knock a couple of pegs into the ground about a meter from your trench, fix a horizontal batten across them and string your line to it.
You can set these level (fiiddly) when pulling your lines, or have four different datum pegs hammered in close to the corners, for height setting. Set your corner block to the line and the height of it to the datum peg. Do all four block corners and set your line to the blocks.
Hey, good morning and thanks for the detailed diagram. It is very informative.
I see where setting out is the most important part of a job, get this correct and hopefully all should go well. I imagine it can be quite hard working around all those lines though.
Thanks again for your help.
Setting out is tricky, yes. We use a builders square and a decent laser level (with 90 degrees built in). You can check your squareness by measuring the diagnals.
A laser level with a square function, does it measure the diagonal then or just square a corner?
It fires a laser beam in one direction and another at 90 degrees to it. On a dull morning I can line the beam up on one elevation then put a pencil mark on the adjacent horizontal batten, to get the other. I set up the lines then check with the builders square and diagonal measurements.
Once you have 90 degrees set out, you can simply measure the other two sides parallel.
Ah, that's great. I have a 360 laser level so I should be able to do this. But, as you say, it is hard to see in daylight, especially when sunny. Mine is also red so even trickier.
Thanks so much for your help.
We switched to green beam a few years ago. Much better in daylight. We set out a free standing 6.5m x 7m garage the back end of last year, and you could see the beam over the 7m+ distance during early morning daylight. Any micro movements of the unit and the beam dances all over the place, when measuring over longer distances, so you need a stable base.
I purchased a red one to tile my bathroom a few years ago and have just kept with that. I bought a receiver last night and that certainly beats trying to find the laser line outside. With blockwork, is it ok to go smaller than the 10mm mortar bed underneath, say at the highest point so then you don't need to pack so much (20mm) under the blocks at the lowest part? Also, how do you know how much extra mortar to add for settlement?
My outhouse is 7.5 x 4.5m. I am thinking the problem I will have the most is trying to get a good consistency of muck as I have never done it before.
Settlement is a usually timber related i.e. shrinkage across the grain etc.
Yes it's ok to screw the beds down on the high points. In fact it's quite normal to have a big starter bed when setting out as concrete shrinks slightly as it dries. Once set however, it is quite stable.
Thanks so much for the reply. So the technical term is screw the beds down. Love it. Good to know that the beds are pretty much stable once dry. I was at Hampton Court palace the other day and noticed the mortar between the bricks there was really small. Amazing consideration those bricks must have been all over the place with not much consistency between.
