contrails (chemtrails)
Status
Not open for further replies.
No just prove you live in the UK, I don't mind doing that because I do. You can't do it because you do not live in the UK. This explains your hatred of this country
Sadly this country is full of British-born natives who hate their own country. It's compulsory in some circles - express anything other than hatred for your own nation and you'll be assumed to be a right-wing nazi or something.
Some are in a very strange place.
You don't see chemtails at night because them in charge turn the sun off. Obviously it goes back at night, but you don't see it because it's dark.
The sky is never too dark to make out clouds. You need to get out more often and look up.
Just seen the first one of today, horizon to horizon, so for all you atmospheric using debunkers. Has the conditions changed from 2 mins ago when there was no trails same height plane.
How do you know it was the same height and same plane? You might have spent your entire life staring at the sky but that doesn't make you a laser range finder, and you'll probably have screwed your eyes as well.
I thought you are supposed to be some sort of IT expert so obviously you are just full of BS
Flight radar 24 and ADS-B exchange :rolleyes:
I thought you constantly stare at the skies, how have you only just seen a plane at 2:30 and then seen two at once? Are you sure you didn't just spot two busses?
First one today - being the first chemtrail at 2.30 when 2 mins before - no con or chem same height same plane type.
Planes two minutes apart never climb to same height on same route.
You can’t judge plane height from ground , only a dumb f*ck would think they can .
Status
