contrails (chemtrails)
Planes two minutes apart never climb to same height on same route.
You can’t judge plane height from ground , only a dumb f*ck would think they can .
I just double checked and planes following each other are typically separated by 1,000 feet in the UK. But 2-3 minutes is roughly the minimum time separation for larger planes.
So one or the other could be true, they could be at the same altitude but far further apart, or they were fairly close and different altitudes.
I never said they were on the exact same route so its you looking dum
No dumbo I use flight radar 24 and ADS-B exchange, they are flight trackers. And Actually with a lot of use of the app you can become good a estimateing heights
So flying through different weather conditions 25 miles apart where air speed can be changing conditions in seconds.You are even dumber than I first thought .
You are trying so hard to debunk that you are not thinking are you
If as you say changing conditions in seconds due to speed then the atmospheric debunk falls down because the chemtrail is constant. And the planes are not separated by 25 miles either - same altitude same aircraft type a few mins apart slightly different heading. One cons - one chems, proof its not atmospheric conditions.
Thats not how plane routing works. If they're on crossing paths then they're a minimum of 3,000 feet different.
A lot of use? Estimate? It lists the altitude in flight radar 24. I don't think you really do use those tools.
2-3mins apart is 25miles at cruising speed . Trail is not constant it starts to dissipate the second it leaves the aircraft .
