contrails (chemtrails)
Planes two minutes apart never climb to same height on same route.
You can’t judge plane height from ground , only a dumb f*ck would think they can .
I just double checked and planes following each other are typically separated by 1,000 feet in the UK. But 2-3 minutes is roughly the minimum time separation for larger planes.
So one or the other could be true, they could be at the same altitude but far further apart, or they were fairly close and different altitudes.
I never said they were on the exact same route so its you looking dum
No dumbo I use flight radar 24 and ADS-B exchange, they are flight trackers. And Actually with a lot of use of the app you can become good a estimateing heights
So flying through different weather conditions 25 miles apart where air speed can be changing conditions in seconds.You are even dumber than I first thought .
You are trying so hard to debunk that you are not thinking are you
If as you say changing conditions in seconds due to speed then the atmospheric debunk falls down because the chemtrail is constant. And the planes are not separated by 25 miles either - same altitude same aircraft type a few mins apart slightly different heading. One cons - one chems, proof its not atmospheric conditions.
Thats not how plane routing works. If they're on crossing paths then they're a minimum of 3,000 feet different.
A lot of use? Estimate? It lists the altitude in flight radar 24. I don't think you really do use those tools.
2-3mins apart is 25miles at cruising speed . Trail is not constant it starts to dissipate the second it leaves the aircraft .
Skipping through 9 pages of tinfoil hat BS show me a single plane that has been flying around chemtrailing the atmos lately..its tinfoil hat flat earther lolz stuff..
Mind you i did laugh at the anti vaxers, now ive seen too much evidence and wish i had listened earlier.
You are not paying attention are you. Using the app and others for a few years and noting the height that the app tells you then with practice you can start to estimate the height just by looking at the plane in the sky
You keep jumping in without reading. I am saying they are on a slightly different route so one has passed and the other crosses very close to the path the other one was at so they have both gone through roughly the same patch of sky yet one cons and the other chems, ruling out the atmospheric debunk angle.
You clearly have not been paying attention have you, with that statement you have just supported chemtrails. You need to read back on the differences between con and chemtrails
To an accuracy of 300 feet? *******s you can.
So on the one hand Air Traffic regulations say that planes following the same track closely should have 300 feet of vertical separation and planes crossing should have a minimum of 1,000 -2,000 feet of vertical separation.
On the other hand we have Aveatry who can judge altitudes by eye who says they were the same altitude.
Its tricky which to believe here.
Strange as it may seem I don’t know any thing about chem trails so I cannot comment in the caper
Dunno if it’s the same principle
But I have had several people pull up when I drive the Transam telling me some thing up
With that car it’s smoking
Yeah it’s unburnt hydrocarbons advancing global warming
My 250 2 stroke Yamaha used to
Lay down a decent smoke trail
