Programming Outputs : output does not activate
23 Apr 2026
France
Hello,
I want to activate an output when the main power is cut off, but outputs "Aera - Fault Present" or "System - Mains Power Off" do not activate when the main power is Off.
Which output are you using ?
What device is it triggering?
Was the mains off registered in the event log?
Power off delay has been set to 0 but nothing changed.
I am using Digi Outputs #8 and the trigger is cuting off main power on PCB.
What device u trying to trigger..... have u actually tested the voltage on the OP terminal with a multi meter?
Panel : Premier Elite 48W Live
Software version : 3.0
When I cut the main power, the alarm is displayed on the keypad but the output does not activate
Output setting : Output Group - Area / Fault Present
Installation Manual documentation :
66 - Fault Present : This output type activates when a general fault occurs i.e. Line Fault, AC Mains Fail, Detector Fault etc. and deactivates when the fault is cleared.
Can you clarify the second paragraph?.
What, exactly, are you wanting output 1 to do?.
Does the device you are triggering use the same power supply as the alarm ?
To clarify the process:
The output is configured so that a fault activates it (Output Group - Area / Fault Present).
To verify if the output is activated during a fault, the power to the control unit is cut off at the main electrical panel. The result is no activation of the output despite the error message visible on the keypad ?
What is the output connected to? How are you verifying that the output does not trigger, have you yested the output voltage with multimeter ?
So you are turning off the mains 230v supply to the intruder panel to initiate a 'mains fail' state, this would then flag up a 'System alert' on the keypad, and you want output one to go active during this?.
WHAT DO YOU WANT OUTPUT ONE TO ACTUALLY DO?, trigger a relay, operate a visual indicator, trigger an input on a dualcom/communications device?-what is the purpose?.
Output one has no inbuilt pull up resistors, so it will only really actually do anything if a load is attached, hence my repeated question-what do you want output one to do.
This information is required to give an educated answer.
Hello,
The goal is to be alerted when the alarm system malfunctions (tamper no, power outage, ... for example). All 8 outputs, including the one in question (output number #8), are connected to a relay that communicates with a GSM transmitter to notify by SMS.
Yes, the input (number #8) has been tested via the control panel (Bell Test - Digi Test) and it does activate the input.
Furthermore, I should mention that the other output is functioning correctly.
For your information, here is my configuration : (output number #8 is the one that doesn't work)
No. Group Type Areas Attributes Notes
1 Zone Group 001 Mimic Armed - * I * * * * * *
2 Zone Group 002 Mimic Armed - * I * * * * * *
3 Zone Group 003 Mimic Armed - * I * * * * * *
4 Zone Group 004 Mimic Armed - * I * * * * * *
5 Zone 030 Mimic - * I * * * * * *
6 Zone 031 Mimic - * I * * 2 * * *
7 Area Full Armed A . . . * I * 1 * * * *
8 Area Fault Present A B C D * I * * * * * *
