Gate width - space?
5 Dec 2012
Hi, following on from my post earlier in the week, the posts are level and secured to the wall ready for me to build the gate
I’m just building a standard z frame gate with 22mm thick timber screwed to the frame
Both posts are perfectly levels and the measurement between the face of the posts is 81cm
What width should I build the frame? Should I allow 5mm either side space? So build the gate 80cm wide?
I’m using standard T hinges and a barrel bolt for the locking of the gate
Not built one in a while so just refreshing my memory
Cheers
Hinge side is most stable but latch side can expand contract 10-20mm over the year . I would leave 10mm either side in dry timber . Gives room for adjustment .
Great thanks, that’s what I was going to do.
my thoughts as its relatively dry 19mm gate stops and 12-15mm gaps each side
is the gate a framed gate or a feather edge ledge and braced styled gate ??
ledge and braced =rails a 15mm gap each side but cladding overlapping 5 to 8mm each side [so face 10 to 16 mm wider than frame] allowing easy shaving to fit for expansion
Hi all I did the job, pretty happy with how it went once I got posts level
They didn’t want a handle or latch on it ‍♂️
