I’m in a 15 year-old Persimmon house and am trying to route data cables from under the floor to a wall box. I can access under the floor from below and have cut out a hole for the wall box in the plasterboard. The problem is that the route down to under the floor is blocked. I’ve attached a photo taken with a cheap boroscope (plasterboard on left, blockwork on right) and I’m guessing the dot & dab adhesive is run continuously along the bottom of the plasterboard, behind the skirting board. I’m trying to avoid any damage to the first floor room but can’t see how i can get past this barrier. Are there any tricks to achieve this? Is there likely to be any more barriers to this routing? The underlying issue is that I’m not familiar with how this age of house is constructed so I’m kind of working blind.
Thanks in anticipation
