Wood behind plasterboard
1 Apr 2013
Norwich
So just want to put some shelves up on a fairly new build (about 25 years old) and would like to know about the construction. Was it standard practice to put wooden batons up at intervals in a room and for plasterboard to then be screwed to the batons?
Not common practice no. More of an alternative solution, if say a wall needed pipes hiding, or insulating, or the wall was coated with something, or the wall needed thickening out to meet another etc.
Generally, 25 year old builds with internal blockwork, would have dabbed plasterboard walls.
So then how do you suggest I go about putting shelves up and putting up a cabinet in a bathroom?
Exactly why I'd never buy one.
You can hang a picture frame from the plasterboard. Anything heavier needs attaching to the block behind it, packing out to the plasterboard surface level. I used thick washers for a radiator I fitted once to someone else's house. It worked, but it was horribly fiddly.
They're designed to be sold profitably, not to be lived in comfortably or repaired.
Yep seems like it. So did a bit of investigation, I found there to be thin metal beams to which plasterboard is screwed on to. Looks like I will have to no idea to get round this now
My stepson once purchased a 1980s building. The bathroom wall/hallway wall were 9.5mm plasterboard glued to 25mm plasterboard (which in turn was glued to another 9.5mm). The wall was held in place by 1" by 1" timber at the top and bottom.
So hollow? You can use standard plasterboard fixings.
